no fuel, s14 w/ s14 sr20
RsrS14
Car: 97 S14 240sx
Car is a 97 s14 with s14 sr20det swap. the car had been running fine until recently, now there seems to be a fuel issue. Fuel pump is getting 12v, no power at sending unit wires for some reason though. Do not hear fuel pump priming. there appear to just be two relays by the ecu, but if i am seeing 12volts at fuel pump doesn't it have to be the pump since its the end of the circuit?
RsrS14
Car: 97 S14 240sx
btw its constant 12v, not just during cranking
RsrS14
Car: 97 S14 240sx
i came here from zilvia because i thought it would be better, but atleast there i got replies!
someone please help!
