no fuel or spark cylinder #4 KA24de
benarovi561
Car: 92 black hatch
please somebody help replaced the fuel injector already, gonna check the distributor and spark plug wire today. and before, when it was misfiring before i replaced the fuel injector and did anything, the spark plug wire kept getting loose from the hole and popping out. somebody hellllp ppllleeeaaassseee!!!
shiro_neko
change your spark plug wire. the clip inside might be loose
rioredstang
Car: 1993 240sx SCCA ITS
Check your plug and make sure the compression washer is on the plug. While you have it out replace it. Its cheap insurance to fix the problem. Then torque the plug to specs.
