rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Tue Dec 02, 2008 5:22 pm
K, so my car has been running crapily. It'll idle, but when I give it gas it bogs out and the rpms will actually drop to about 1.5k rpm and will occasionally hit just enough to maintain that rpm. When I let off the gas it returns to it's normal idle. It'll gain rpm half hazardly up to about 1/4 throttle, after that it just bogs out and misfires on all 4 cylinders everytime, no hit's, all misses untill I get below 1/4 throttle agian.
So I decided to check fuel preassure. I was thinking the preassure regulator might be stuck open returning too much fuel causing it to have enough fuel to idle, but not enough to run WOT.
So I unhooked the fuel return line and planned on having a friend block it so that it would increase fuel preassure causing the car to run properly. (this would prove my theory of stuck open regulator) Instead what happened is there was NO fuel coming out, AT ALL. We just stared at this fuel line hanging disconnected with nothing coming out of it while we reved the engine and played with the throttle (it obviously ran exactly the same)
So what does that mean?? How in the hell could their be absolutely nothing coming out of the fuel return line???
