No Fuel and No starter
96Turbo
I just finished my first five speed swap and engine swap and I have no fuel coming from the fuel hose and no starter kicking over. can any one help me track this issue down, how do I check the fuel pump to know if it is working? thanks.
180fan
Car: 89 fastback
first, did your fuel pump fuse blow? The 5 speed swap shouldn't have messed with any of the wiring for the fuel pump. Did you bypass the switch on the clutch pedal?
96Turbo
Do I have to mess with that switch when doing the swap? If so I have not moved or done anything with it. That may be my problem Any more imput would be apreciated. Thanks.
