We'll see what the picture shows but the only smallish ground wire coming from the bundlle looks like it bolts to the (square) frame about 2" aft of the pair of large ground wires bolted to the frame. The hole is pre-tapped. You'll need a 10mm bolt.mikes94q wrote:....... Mainly close to the battery from the main fuse box there is a large wire loom that goes down below starter, where does the small ground wire coming off that loom attach?
