SoClean_350Z_King wrote:
Will it effect my oil pressure gauge, because it is passx the
Max of 120
Most likely your oil pressure sensor is bad. The easiest way to tell is to turn the key to to the ACC position and see what the gauge does, I'm betting even without the motor running thatv the needle gets pegged.
I replaced mine a couple of years ago, I think the new sensor was $80 from the dealership parts counter. Don't go the cheap route and use one from an Infiniti G35, they are not the same. Both will alert the idiot light on the dash, but only the one for the Z will relay the pressure and accuate the gauge in the triple pod.
Welcome to NICO!
