No electric power?
tazjig
Car: 1990 240sx (SR20)
just a quick question, i was wondering if having no power to the interior and or the fuel pump, but the car will turn over, could this be caused by not hooking up the ground cable on the back of the engine from the block to the fire wall? because i hooked up the ground from the battery to the engine?thanks
quiksilvia
Car: 95 s14 se
battery to engine? thats not right, and ywa u should hook up all grounds, check ur fuses for the fuel issue.
electricproblem
yes it does sound like fuses never heard of groundin the block off the battery
yellow_jacket
Car: 95 240sx
Your negative battery cable should run from the battery, to the frame, then to the intake manifold. If you don't have it run this way, you may get all sorts of funky problems. Much like your interior power problem.
tazjig
thanks, i figured out the problem, see i had my battery grounded to the intake manifold, and i didnt have the engine grounded to the frame so i ran a ground from the manifold to the frame and every thing is hunky dory, thanks again
