no electric current flow
jmerle
Car: 03 qx4
When turning ignition switch, a total loss of electric power occurs. Power returns if I shake the fuse box on right side of engine. Fuses with clear tops appear to be O.K. Any ideas how to check? 2003 QX4.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Have you made sure the battery terminals are free of corrosion and tight (but not overtightened - that can cause the posts to crack and you'll have unstoppable corrosion)?
