No EGR Problems
studstill_1
Car: 1993 nissan 240sx se and 2002 infinity i35
Has anyone bought an aftermarket header and not had any egr problems. i looked throught the forums and nobody comes and out and says buy this header it has worked great and everything bolted right in. i am starting my ka-t project and have found most the stuff i want except for the header. Any help would be great.
lrb_2000
Car: '91 Nissan KA-T hatch
I've never had problems with my egr on my 91.. it's been off the car for a long time and there hasn't been a check engine light or anything.
jik
Car: 1992 Nissan 240sx Fastback
you are looking for a header for your ka-t? the egr not throwing an engine code is an anomaly for your car i guess. every 240 i owned throws a code when you take the egr off.
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
^ Mine didn't, I have to eliminate my EGR when I installed my NA headers and had no problems. Its been fine so far. ( about 6 months)
studstill_1
I dont want to just cover up the egr i want a header that i can just bolt in with no problems .
s14tan
studstill_1 wrote:I dont want to just cover up the egr i want a header that i can just bolt in with no problems .
That means that you can't go cheap and have to dish out some money for a Exhaust manifold by a company that did actual R&d and made it (EGR Valve) fit correctly.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
jik wrote:you are looking for a header for your ka-t? the egr not throwing an engine code is an anomaly for your car i guess. every 240 i owned throws a code when you take the egr off.
FYI, if you look in the FSM there is an extra sensor thrown in the california model cars that monitors the EGR temp. ONLY in a california car will EGR removal trigger a code.
Studstill,If your going KA-t your probably better off just ditching the EGR.
studstill_1
Well im not sure if my car is a california model. how do i tell.
studstill_1
and also is there a good header that has the egr completely removed so i dont have to rig up some kind of patch job on it.
ken240sx
Car: '92 KA-T 240sx, '08 Vette + Spray, '09 Benz C300, '98 Trans Am + Cam & Spray, '03 Acura TL Type S
Still not sure if you're talking about a header or a turbo manifold....but for a tubro manifold....most of them don't have an egr port or anything for emissions.
