Here we go, I to have suffered the no dash light problem on my 240. I had a friend install a cd player for me because i dont normally do installs. My dash lights did not work afterward and i worked on it for three months before giving up and fixing it my way. Here is what i done, Checked every possible wire under the dash for a bad or wrong connection every thing was fine and they all had continuity so i assumed no short. I then reinstalled my factory harness since it had been removed to install the cd player still no dash lights. Now frustrated with the problem i tried direct power to the dash lights, i belive it is the red wire with yellow stripe to the red wire with black stripe, only i had two of each wire they both work the same components i still can not figure out why there is two of them, any way IT WORKED the dash lights came on. I then tested the head light switch, i turned on the head lights and god damn the dash lights went out, what, i turned the head lights off the dash lights came back on, only now the head lights stayed up too. Disconnected the wires all went back to normal still no dash lights with the switch turned on. I then decided to run direct power to the dash from the fuse block from another compent that has power when the ignition is on. I hooked the red wire with yellow stripe to the air bag fuse i belive it was, my car does not have airbags but has all the connections that work. This to WORKED only when i turned the park lights to the on position the lights went back off, the head lights worked though, only the damn dash lights dont work with the swith on. this lead me to belive it was a ground problem, every ground checked out ok. My friend has a 240 and works at infinity service and we both go to the same automotive school, he does not have a radio in his car so touched the red wire yellow strip to the red wire with black stripe to see what would happen the dash lights came on with out switch being on. I dissconnected the wires and tried the switch no dash lights, this is definitly how the lights was blown in the first place. He too can not find a fix for this problem. I decided to bypass all the factory wiring in case of a missed short or blown link, i removed the entire dash cluster and wired the dach lights to the fuse block from behind the cluster, direct power. I then grounded it as well without the stock wiring, two new wires and the dash light up, i turned in my park lights and damn it again they go off. How can this be its wired through the cluster it is not even on the circuit with switch any more how can the switch have an effect on the lights. The following week i decided this was not cool turning on my dome light to check my speed in police patroled areas. I went back to the board and decided it had to be the switch some how,some way. i read a comple of the forums asking about the same problem and they lead to the tcu box or variable time control box under the fuse panel. I replaced them both guess what no dash lights, although replacing the switch made both of my high beams work where i previously only had one. I pulled my old tcu apart and every thing looked fine. Anyone can have it if they want it, Hell i have two of them because i was so sure that was the problem i was going to give one to my friend for blowing his lights. I still have both. I then read that maybe my dimmer swich light was blown and not allowing voltage to the dash, i checked and YES it was blown all happy again i stopped a two auto part stores to find the bulb none had it, they recommended the wreck yards. I went to nissan heaven the next day on my lunch break from work, found the bulb it was good installed and no the dash lights did not work. ENOUGH OF THE DUMB ****!!!! i picked up 10 feet of wire and ran on end to the red wire with yellow stripe, the other end i ran to the left front park light, I tuned the swich on and GOD DAMN IT I HAVE DASH LIGHT WITH THE SWITCH ON. This may not be the way to do things but i can now see my dash at night and have both of my high beams, every thing on my car now works. If any on finds a official fix for this problem drop me a line because i have tried evrything and this works fine for me. If you need further instruction on how to install this jumper wire with a fuse e-mail me @
[email protected]
