vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Thu Aug 10, 2006 6:50 pm
Ok, so you did a continuity test on the fuse links. Pull the green fuselink for ignition switch. Turn multimeter to dc volts and put one probe on fuselink terminal and one probe on ground. One of the fuselink terminals should give you 12 volts. If you get 12 volts, turn multimeter to continuity and put probe on fuselink terminal that had no voltage and connect other probe to first position on ignition switch. you should get continuity with key out of ignition.
