alright did some research already but have no lights for dash corner lights or the brakes unless i press the brake light i looked around and it seems its a fuse under the hood no idea where its located yet but gonna figure it out in the morning has anyone else had this problem??
yeah headlights work everything else works fine i checked all fuses under the hood gonna check again tomorrow to dark now but hopefully i can just figure it out really fast im just gonna re-check all of them
Postby
andy107 »
https://forums.nicoclub.com/andy107-u117580.htmlThu Apr 07, 2011 2:39 am
Check your headlight switch. I had a similar issue with my s13 coupe. Took my headlamp switch apart and cleaned the contacts in it. BAM everything works. There is a write up about this issue. Another thing to check is a small white box located under your fuse box on the driver side kick panel. Forgot what its called but its some sort of timer I believe. It burns out when people install aftermarket stereo decks and accidentally cross wires. I may be wrong so don't quote me on this. There is a write up on that also. Just search.
Postby
michael_grigoras »
https://forums.nicoclub.com/michael-grigoras-u138237.htmlThu Apr 07, 2011 3:18 am
alright so checked all the fuses today turned out to be a burnt out 35 a fuse under hood and a bad light also fixed and working now thanks for the help everyone! all i gotta do now is put leds for the dash and gauges on the pillar lol
