I've had my M35x for about 4 years now and boy has it been a journey. This is the first car I've ever worked on and I've already replaced many components on my own (thanks to Youtube), so I went ahead and decided to replace the display screen as it had melted from being parked in the sun for too long. As I was replacing screens, I decided to unplug the battery so that there was no chance of getting electrocuted or short-circuiting something, and my dumb a** didn't realize I was supposed to remove the negative side before the positive.
As I was removing the positive terminal, the wrench I was using had touched some metal while also touching the terminal and created a spark and some smoke. Ever since that happened the car will not crank or start, however the rest of the electronics are functioning. My first instinct was that I had a blown fuse or relay, but after checking all of my fuses, switching out some relays, and even going to the junkyard to find replacement multi-fuses (50/30/30 and 40/30/30), it seems like it probably isn't a fuse or a relay... unless there's one I missed somewhere.
I've been doing some research and was thinking maybe I blew a fusible link (still not too sure what that is), or possibly need to replace the positive terminal altogether? I was also thinking, however, that if this was the case then wouldn't the car get no power at all?
CAN SOMEONE PLEASE HELP ME? I have errands to run and hate asking friends for rides all the time
