MooMoos14 »
https://forums.nicoclub.com/moomoos14-u104494.html
Sat Oct 10, 2009 3:22 am
I just finished putting in my buddies s13 ka24de in, Swapped the intake manifold and dizzy so it'd plug right in, My s14 was Auto before I did the swap, Did the swap. I believe I did all the wiring right for the clutch cancel switch and neutral position switch.. I have power to the car because my lights ac electric fan and everything else works inside the car, I have fuel because I can hear the fuel pump cut on. But when i go to start the car, Nothing. Not even a stutter just dead silence.. Also since my car is a 94.5 s14, OBD1 I got an Obd2 transmission harness, So the triangular switch with 3 wires off it, has nothing to plug into. I'll produce photos in a few.
Here's the 2 plugs that I have nothing connected to that's under the fusebox. The new OEM harness I got from a guy on here, Only one plug would plug into those series of plugs, (As seen in photo)
Here's 3 plugs on the side of the fuse box that I have no plugs plugging into?
Can someone tell me what I have to do with these plugs? And Dont refer me to any of those crappy half described auto->5speed write ups, They suck at describing anything, Or I wouldn't be here..
