hnugen wrote:I checked the service manual and replaced the 7.5A elect. batt. fuse and yellow wire is good now. Black still has no ground, which is not a problem because the screws holding the unit in and antena wire will provide ground.
You're damn right it's not a problem. Your car doesn't have a ground wire in the radio wire harness.
Yeah... you learned it the hard way like most of us did the first time. If you'll look more closely, you'll see that when you follow the 'ground wire' from your aftermarket harness adapter to the factory connector, there isn't a wire in the connector to connect to it.
