hungryjoseph »
https://forums.nicoclub.com/hungryjoseph-u50257.html
Tue Nov 11, 2008 5:33 pm
I replaced my head gasket after over heating and blowing the first one. The temps shot up pretty high but it was during idle. I didn't know how high the temps were cus I ran inside to take a poo and came back to find it sitting above 250. I find out later that there is coolant leaking through between the head and block around cyl #3, I did a compression test and saw that it was 55psi, while the rest were 145 - 150. I poured a cap of oil and it bumped it to 60psi, not enough to point the finger at the rings so I assumed it was the gasket based on the coolant leaking outside from the head and block, and the low compression on the cylander that was next to the leak.
I got the head resurfaced, new valve seals, guides, hot tanked, got an apexi metal headgasket, stock size, put it on, torqued it down with arp studs, got it mounted in the car, my battery drained out so I cranked it over by hand to see if compression was somewhat ok, and I got 60psi on the cyl's except cyl #3, which gave me like 10psi no matter how hard I turned the crank. I understand that turning it by hand is inaccurate but a 50psi difference tells me something is wrong. what would it be? crack in the head?
