No Compression!! Need help!
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
So I just put on a new head on my 210. (Finally, after like 7 or 8 tries with coolant leaking everywhere....but that's another story). Anyway, so this new head's combustion chambers are shaped differently. Other than that, they are the same. I got the thing all bolted back up and went to start it, and it was running really rough. It was also backfiring a ton. I tried driving it, and it didn't even have enough power to make it out of my driveway (up hill). It has fuel (obviously, if it's running). It also has spark. I checked all 4 plugs.
I pulled the fuel line off and cranked it over and it cranks over REALLY easy on all 4 cylinders. Is it possible that the different shaped combustion chambers are causing lower compression *that* bad to the point the car barely runs? I figured it might lower them a little, but realistically, how bad? Stock compression is 9.0:1.
It's the A15 motor, '81 model year. Any help is appreciated! I haven't done a compression check yet, but I'm going to borrow my friend's gauge and do that tonight.
DAEDALUS
Car: 1990 Infiniti Q45
Sounds a lot like the timing is off. Valves aren't closing when they should be perhaps. When you say that the combustion chambers are shaped differently, you mean that the volume above the piston at TDC is different?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
DAEDALUS wrote:When you say that the combustion chambers are shaped differently, you mean that the volume above the piston at TDC is different?
Yes.
Also, I don't know how the timing could be off. It is a pushrod motor, so I didn't mess with the cam at all. And I adjusted the valves when putting it back together.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
DAEDALUS wrote:Sounds a lot like the timing is off. Valves aren't closing when they should be perhaps. When you say that the combustion chambers are shaped differently, you mean that the volume above the piston at TDC is different?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Ok, here's a little update:
Plugged in the compression gauge. Got compression in all 4. Spec is 192psi, I got about 210 in all 4. Guess the head I put on actually has a little higher compression.
Anyway, still runs like crap....and I've got two theories:
1st one is that with the higher compression head, I need to make some adjustments. I gapped the plugs closer, but that didn't seem to make a noticeable difference. Tomorrow I will try to retard the timing a bit and also adjust the fuel mixture on the carb.
2nd one is that I got some vacuum lines mixed up. My friend looked over the car and found a vacuum nipple I was missing a hose on. Only problem is, I don't have a vacuum hose to put on it. I'm going to look at the vaccum diagrams and try to figure out if I have a vacuum leak.
I'm leaning towards #1, but #2 maybe a culprit too.
Reverend...like I said, it's a pushrod so I couldn't have screwed up the cam timing. And the valves were adjusted when I put the rockers back on. I'm pretty sure it's fuel related (waaaaaaaaay too rich) because I've got spark on all 4's, yet I can pull plug wire #2 or #3 off and it doesn't make a difference in the way the car is running. I think maybe the fuel is flooding the cylinders.
Also, I just thought of this....the above statement makes even more sense since it's #2 and #3 that make no difference. #1 and #4 kill it. They are also the farthest away from the carb. So that means they are running leaner than #2 and #3. And if it's really really rich, and #1 and #4 are running lean, they are really running normal. Which would explain why the car dies if those plugs are pulled! Haha! Maybe I just thought of the answer to the problems.
Any more insight is much appreciated though!!
