vacnsewmedic »
https://forums.nicoclub.com/vacnsewmedic-u19727.html
Sun Jan 23, 2005 6:47 pm
you can replace one, the machine shop will let u know if others are bad, most likely thats the only one thats bad, so act like u know what your talking about or they may take ya to the bank,,,,,,,most machining should cost a flat 150-175.00 plus parts.....one valve isnt much......the gaskget set is about 80-100.00 .....so all u have to do is pull the engine.....
Im a tell ya i thought it was going to be hard.........it was easy sh...t....when u pull the head keep the intake manifold hooked up to it,,,to me it was easy to pull out that way.....easy bolts to get to and when u pull the head out mark the hoses so that u know where they go back......
