Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Oct 16, 2007 7:12 am
Did you reuse the stock clutch and pressure plate? I find that the stock equiment is really squishy and weak.
I have never seen the TO bearing fall out without it alerting you that it happened. Not to mention it's clipped to the fork. If you want to be doubley certain, pop the cover off the back of the oil pan (it's the small one with two bolts holding it in) and look inside the bellhousing.
More than likely, your pedal is just out of adjustment. I've seen out of adjustment pedals really make a clutch feel soggy like it has air in it. So long as you're getting return on the pedal, you should be good. Just double check the pedal height and rod length.
