adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Tue Jun 29, 2010 11:56 pm
I'm kinda adding to what S13_RB25's is saying... get rid of that damper box thingy right next to the slave cylinder. Careful when you bend the hardline, you DONt want to pinch it. FRsport sells a stainless steel clutch line that kinda deletes the damper thingy and directly connects the hardline to the slave. I think I paid like $25 or something... its a great product, highly recommended.
and since you put in a new clutch, you might as well swap out the MC and slave while you were at it. It shouldnt cost that much... I think an OEM slave was like $30ish and OEM MC was like $40-50... you can even go like $20 cheaper with the factory replacement ones too. they work just as good imho (for stock clutches at least)
but about your whole problem about your clutch not engaging sounds like you have air in your system. Bleeding your system should fix it, but since you said the fluid was dirty, I'd highly recommend flushing it completely out and tossing in fresh new fluid. Bleed it more than once... you can never be too sure, lol. Use Dot 3 brake fluid.
good luck. I had this problem last week, I ended up replacing my old a** MC and tossing in new fluid, and my clutch pedal feels great now.
