no clutch pedal pressure
RBKIDD
Car: 92' RBsilvia
07' TBSS
i recently installed a new clutch and resurfaced flywheel. the old slave was leaking so i replaced that too, now after everything is in and back together i cant get any pedal pressure. I bled everything and there is no chance there could still be air in the lines. i opened the bleeder on the slave cyclinder and had my friend push down on the clutch and it was a steady streem coming out of it, im out of ideas of what it could be, can anyone help?
boznuttz
Car: MS13
Check the MC and firewall for any fluid. Run your finger along the lines as well, it's not uncommon for the stock lines to corrode.
Do you also still have the stock clutch dampener attached?
yellowcar
Did you bleed the master first?
