11scotthair11 »
https://forums.nicoclub.com/11scotthair11-u285978.html
Sat Jan 25, 2020 5:16 pm
Can someone please help me troubleshoot my problem? I have an 05' Xterra with 172,000 miles on it. I had a timing chain skip, and decided to do a full timing chain replacement with new chains, sprockets, guides, and tensioners, etc. The repair itself was routine, and was completed without incident. After reassembling and ready to start, I have no check engine light, with they key in any position, "no link" with the ecm when I try to pull codes, and no crank whatsoever. Just a single click from the area of the in- cabin fuse box on the passenger side. Battery is almost new, and charged to 12.85 volts via my multimeter. All accessories functioning EXCEPT windshield wipers, turn signals, power windows. Did find a blown dtrl fuse. Will NOT perform IPDM self test. No power to several fuses; fr fog lamps, injectors 02 sensors, reverse lamps, ABS ECU, A/T ECU, fuel pump. I do have verified good power and ground to the IPDM. Any thoughts?
