WAbernethy »
https://forums.nicoclub.com/wabernethy-u849.html
Sun Mar 07, 2004 9:32 pm
From my FSM:
1990 ENGINE PERFORMANCETheory & OperationNissan; 240SXINTRODUCTIONThis article covers basic description and operation of engineperformance-related systems and components. Read this article beforediagnosing vehicles or systems with which you are not completelyfamiliar.AIR INDUCTION SYSTEMSWIRL COMBUSTION VALVE (SCV) SYSTEMNOTE: For location and identification of ECU terminals, seeappropriate L - WIRING DIAGRAMS article.The SCV system is designed to improve engine torque and powerproduction by increasing or decreasing intake manifold inductionvolume under different driving conditions. A limited induction volumeis desirable at low or medium speed under heavy load. This willincrease intake velocity and improve atomizing of fuel and combustionefficiency. An increased induction volume is desirable under heavyload and high speed condition.SCV system consists of swirl control valve (built into intakemanifold), diaphragm type swirl control valve actuator and swirlcontrol valve solenoid.SWIRL CONTROL VALVEValve is used to modify the induction passage of the SCVsystem. It is set in the fully closed or fully open position by theswirl control valve actuator. Valve actuator is regulated by the ECU-controlledswirl control valve solenoid.SWIRL CONTROL VALVE SOLENOIDSwirl control valve solenoid receives power from a 10-ampfuse in the relay box. Solenoid is energized when ECU provides aground for solenoid through ECU terminal No. 12. When ECU activatessolenoid, manifold vacuum passes through solenoid to swirl controlvalve actuator, pulling swirl control valve closed.
The shaft sticks out of the back of the manifold, somewhere near the egr and it should have a little actuator attached to it. Why would I make this stuff up?
