You answered your question previously in your post. Rubber detiorates from moisture saturated brake fluid not being flushed soon enough.Kiven422 wrote:Didn't bother bleeding it because I felt there was no need to.
Heres what I don't get... Why did the brake hose start leaking in the first place?
Its alright buddy, you made an educated guess and offered some sound-though deliberately frightening-advice.maxnix wrote:I thought the Consult with an ABS card was required to activate it.
If it is not bled, then stagnant fluid is left in it. Also, one couild go out and activate the ABS while driving and do multiple flushes. Guess I need to read the FSM more carefully or Dennis needs to elucidate.
Reading my Book of Revelations AKA the 2000 FSM, and, removal of brake fluid does not state the anything must be done with the ABS system to completely remove said fluid.maxnix wrote:
Be sure when you flush your brake system after rehabilitating it and using new fluid, the technician has a Consult to activate the ABS so that fluid is also flushed. Or else you will be replacing your ABS unit also to the tune of about $1,100 for the rebuilt unit alone.
Because hydraulic fluid is hygroscopic and it ages with temperature variations.Kiven422 wrote:Oh well this is the first time I did brakes without bleeding the system. Now I know.
But why... I didn't open the cap or anything.
There is brake fluid in the actuator. Thnklilttle old ladies that never get into the ABS cycling (which is me as it only happens once or twice a year) and you have trapped old brake fluid.elwesso wrote:I dont think anything is necssary for the ABS. all the brake fluid goes through the ABS thing anyway, which is why on ABS cars you do LR, RR, LF, RF instead of the other way for non ABS cars...
I wouldnt worry about it. its sorta like a transmission flush, 95% is good enough.
98% is twice as good as 95% new???? Stop the insanity!!!!!!!!!!!! The law of diminishing returns has come into play here for those without OCD.Change the damn fluid at least every 2 years,and quit obsessing over it. Easy to exercise ABS in snowy,icy,or even rainy weather if one wants to...also the ABS cycles {safety self tests}every time car is started and backed down driveway.maxnix wrote:There is brake fluid in the actuator. Thnklilttle old ladies that never get into the ABS cycling (which is me as it only happens once or twice a year) and you have trapped old brake fluid.
One must always strive for 100%, even it it is unobtainable. Think of it this way. 98% new is twice as good as 95% new.
Numbers don't lie. 2% is 40% of 5%.qship96 wrote:98% is twice as good as 95% new???? Stop the insanity!!!!!!!!!!!!
Isn' there a small metal spring clip that slides over the brake line holding it to the bracket?Kiven422 wrote:So I was working on the brakes today... I unscrewed the metal brake line but can't seem to get the hose off the first metal bracket, is there a certain way or what?
? There is brake fluid in the actuator?maxnix wrote:There is brake fluid in the actuator. Thnklilttle old ladies that never get into the ABS cycling (which is me as it only happens once or twice a year) and you have trapped old brake fluid.
Well there is the metal bracket... I know how to get the middle one off... but the one coming from inside the car to the hose is impossible to get off, i just don't understand how I can do it without braking something... any ideas?bullittandy wrote:
Do you think the hydraulic brake lines on the actuator are just for esthetic effect?RAP wrote:? There is brake fluid in the actuator?
DO YOU HAVE AN IMAGE OF THE INNARDS, AND, A DESCRIPTION OF THE ACTUAL WORKINGS OF THE ABS UNIT ? ? ? IF SO, LETS HAVE IT ? ? ?maxnix wrote:Do you think the hydraulic brake lines on the actuator are just for esthetic effect?
I'll take a free hug!Jesda wrote:I dont think getting nasty is necessary. Everyone here is just trying to help.
FREE HUGS!But no funny business.
Oh hell, it's a RP love fest. Maybe ya'll could do this back channellasoyafan wrote:
