No Brakes, please help...
Kenji Kamuro
Car: 1993 z32 2+2
alright, short and simple... I have no brakes. while sitting at a stop light my engine starts sputtering (figure its the intake piping again :tisk: ) next thing I know, brake pedal shoots up off the floor with good amount of force. I slam the pedal back down and nothing, i keep rolling. the resevoir emptied itself completely. (all fluid into the lines) any ideas whats wrong..? did i collapse a vacuum line or blow the booster diaphram? I've even bled the lines multiple times in hopes its just an odd air bubble stuck somewhere.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Brake booster vacuum line. It's the big vacuum line on the top of the brake booster. It's most likely disconnected, but it may have cracked. Just give it a good look over.
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
If you emptied the fluid reservoir on the master, then there is more going on than a vacuum leak. I would check the master first, sounds to me like it failed. Find where the fluid went to be sure.
