DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Nov 28, 2002 10:58 pm
There are actually 4 bulbs, so the odds are quite slim thay're the problem. A year ago I would have said it's impossible, but I actually have a friend who let all 4 rear bulbs burn out on his Corolla. But 1 bulb passed a continuity check (intermittent) and troubleshooting the car became an excercise in patience and near-futility.Check the 15A fuse on the bottom of the right fuse column.The bulbs and the shifting problem might be related; the 2 systems are related from a circuitry standpoint. Maybe it's a bad ground, though I would think you would have other problems.Not sure what accountability the shop has in regard to the warranty, but if they're the ones that sold it to you I doubt they'll find you need many repairs. You will want to have a list of things on hand that you suspect need repair when you go in. (Add the chain guides and see what they say!)
