donldsn wrote:......I had a similar problem before and it was melted bulb base. This time bulbs are not melted, fuses are all good, sensor in trunk I replaced about a year ago......
Take a look at the sockets in the brake lamp module. If the bulb leads were melted then so were the leads on the sockets they plug into. Also inspect the wiring in the module looking for melted insulation or charring. Did you use long life (LL) bulbs when you replaced them?
Don't rule out the new brake lamp sensor as the culprit quite yet. A year is plenty of time to melt the ground wiring/circuit in any of the Q's sensors. If you're handy pull the brake sensor apart and look for melted or discolored solder, especially on the ground circuit. I was able to repair mine with a simple resolder of one solder joint.
Are all your dashboard, center console, and door lights working?
