No Brake Lights, No Cruise Control, No Transmission Shift
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Hey guys,
I just went for an inspection and my Q failed even after all the work that I've done.The cruise control doesn't work (the light comes on in the dash, but it won't set), the brake lights stopped working (I just replaced all the bulbs), and the transmission shift lock won't release unless I hold down the shift release in the center console (this I mentioned before).
What are the chances that these are all related to one common problem? Anyone know where to start?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Check your fuses...... However it seems to me like maybe the brake switch under the dash is toast.... its a simple part to get and to replace...
Do the front and rear hazards still work?
Q451990
I agree with elwesso... the brake lamp switch can fail and cause the brake lights not to work - as well as the shift lock issues. Happened on Q1 at about 105K if I remember correctly. The only warning I had was an occasional "pop" in the radio when I would apply the brakes - probably the switch arcing.
The Cruise has a separate brake switch - but I don't know if the control looks for both or not...
Heath
lino
Jesda wrote:Do the front and rear hazards still work?
I just ran out to check. Yes they do.
elwesso
2007 BMW M Coupe
the cruise runs off both... Is uses mainly the ASCD brake switch but the other switch has to work in order to complete the circuit.
lino
elwesso wrote:Check your fuses...... However it seems to me like maybe the brake switch under the dash is toast.... its a simple part to get and to replace...
I just checked the fuses and they look ok.Which part number is the right one for the STOPLAMP SWITCH:
25320-75A00 or25320-4M400
lino
elwesso wrote:the cruise runs off both... Is uses mainly the ASCD brake switch but the other switch has to work in order to complete the circuit.
So basically, I should buy the Stoplamp switch first and see if that corrects the cruise control problem, right?
elwesso
2007 BMW M Coupe
i think it should fix both.....
The first part number is the one you want.
lino
Thank you very much. You're always there for me in my time of need. I really appreciate all your help and kindness.
lino
The local dealer is still closed for the holidays, so I called the next closet one to get an idea on the price of the STOPLAMP SWITCH #25320-75A00 and it's $17.70 up here as opposed to $3.92 from Joe. That's just ridiculous, but I need the part right away so I'll have to pay the premium. I can't drive the car with no brake lights.
elwesso
2007 BMW M Coupe
sometimes you cna haggle the price..... Say I have another dealer over here that will give me the part for $5... Just try, worst they can say is no!
lino
Bought the Brake Switch today, but unfortuantely, it's not the Brake Switch that's the problem. The fuses are all ok, there is ground, but no power. Maybe I have to start chasing the wires for a broken connection. I have no idea where the relays are or where to start.
Q451990
Don't forget to check the under-hood fuses as well...
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
follow this link:
zerothread?id=120069
lino
I found the problem. I had a burnt socket behind the fuse panel. The brake lights are working and so is the transmission shift lever. The cruise control had a button missing by the switch and so we repaired that and teh cruise is operational once again.
elwesso
2007 BMW M Coupe
glad it was fairly easy!
lino
elwesso wrote:glad it was fairly easy!
$80 - problem solved
