rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Sun Oct 10, 2004 4:36 pm
1st off, you should tap somewhere else to get vacuum and boost readings. Try tapping off the fuel pressure regulator. If u dont know where that is, follow the fuel rail from the FRONT of the motor goinh BACK towards the firewall. At the end of the fuel rail you will see what looks to be a mushroom looking thing. That is the FPR.. You should see a vacuum line running from it going DOWN toward the back side of the intake manifold. That line itself is the 2nd best place to tap for vacuum and boost pressure. On my ka motor, I removed ALL the emission crap possible and I found 3 open ports that were welded directly to the manifold and they were used for emission feedback. All 3 i was able to get a vacuum and boost pressure signal from..!!! I only used (2) of them. 1 for my boost gauge and the other for my bov.
2nd, if your trying to read boost from a stand still by just reving up the engine, good luck, it WONT happen..!! If your turbo is smaller than a T25, then maybe you will get some boost, but not much.
3rd, on your turbo, your saying that on the exhaust outlet there is a 2nd tiny hole..?? If so, that hole is there for when the INTERNAL wastegate opens, the bypass exhaust gases will pass thru that hole and mix in with the turbine's ex gas..
