Jost »
https://forums.nicoclub.com/jost-u8685.html
Sun Oct 26, 2003 12:18 pm
Slidn', Man, your problem could be hard to diagnose. Take your time and start to backtrack and check EVERYTHING! Make sure all vac hoses are hooked up, no vacuum leaks. If you are sure of the timing, and the turbo is supplying air, then that eliminates those two things. Next are plugged injectors? Bad spark plug or plug wire? Engines need a few basic things to run right: air, fuel, ignition. The ECU needs to be monitoring and managing all the sensors as well. Keep looking for the culprit, don't give up. It's probably something simple, usually is. Good luck. Let us know what you find.
