ninety1two40 »
https://forums.nicoclub.com/ninety1two40-u61449.html
Sun Jul 06, 2008 2:17 pm
Ok here's to sum up the past events:
1) had the fuel pressure and timing incorrectly set, went for a 5minute drive and the exhaust manifold and turbo exhaust housing was cherry red.
2) Fixed the fuel and timing issues, converted over to a blow-through MAF and vented the BOV (Greddy RS) to atmosphere. Went for a drive and everything was great, until I heard a small "pop" and the turbo won't build pressure. Not even 1psi. Figured that an intake hose popped off so I limped it home and found out that there was no blades on the compressor of the turbo side. Crap... But the car still idles really nice, no weird sounds of pieces of turbo in the engine.
3) Took off the turbo today and replaced it with another used stock turbo. Vacuumed the whole intake and exhaust manifold (found out that the exhaust turbine was also MIA) and did a pressure test on the whole intake system, it held very nice at ~15psi (I only run the stock pressure of 7psi).
So I started the car up, let it warm up a bit and gave it a couple free revs, I can't build any pressure, not even 1psi! I didn't try to rev it too much I don't want to blow up another turbo. I do here some air rush out of the BOV when I let off the throttle. I'm going to check the swing valve by the FSM now. I did push the arm and it opened when the turbo was out of the car. And it seemed to work fine, but maybe it didn't close??
If anybody has any other ideas let me know. Thanks!
If you click on my sig you can see some of the specs on my car.
