no boost
afmafia
i have a small problem im was driving and my was running great then i started to boost and there was no power. boost gaue was at 5 the i step n gas it went to no power or boost at all then i came to complete stop and my rpms went to zero and then went back up to 1000. after this happen my car had a lilbit more power but wazs still sluggish . i have an aem ems standalone .
Modified by afmafia at 2:33 AM 8/19/2005
spider_slayer
Car: S14 240SX
S13 240SX
please edit your post. the poor grammer and spelling makes it hard to understand.
in any case.... check for boost leaks. i am not sure why your gauge is registering boost if you are not moving any faster. also, if your bov is not recirculated then it will cause the car to stall out or close to it. some more information would be helpful.
afmafia
bump
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
yeah you should edit your post man. You have a vac. leak some where. Its gotta be pretty bad. Check your intercooler piping and boost lines. It could also be a maf problem.
afmafia
ya i found the problem the nuts on my manifold that were holding my turbo one came off and created a big boost leak .
