no boost in first.
burnout 180
Car: 1990 s13 180sx ca18det
I have a question with my t3/t4 i'm getting only about 4 or 5 psi in first gear even if i rev all the way to 7k but in all other gears i'm getting full boost(12psi) at around 5k.
Why do you think first isn't getting full boost what could be wrong?
boost_boy
burnout 180 wrote:I have a question with my t3/t4 i'm getting only about 4 or 5 psi in first gear even if i rev all the way to 7k but in all other gears i'm getting full boost(12psi) at around 5k.
Could be the size of the back housing. You could have a leak at the wastegate's valve. But from what you just posted, sounds like you just got too much back housing for this little engine.
Dee
