No Boost in 1st Gear and more
turbo98_240sx
Car: computers, cars, anything that can do something and be made to do it faster stronger or better
Ok so I'm a little farther on my car seems like for every step forward I take two back. First Question is what should my timing be set at for the greddy turbo kit because we pulled the distributor to get at the mainifold bolts and well now timeing is screwed up. I busted out the timeing light and it was about 17 atdc. Should I have taken off the crank pos. sensor to do this? I think that there is a boost leak somewhere but I don't know how to look for it other then feeling with my hand for air being sucked along the pipes and intercooler is there a good way to check it out? What about with a steascope? any sugestions?
Also my car seems to lag more then it should i changed to the fpr for my boost signal and it seems that there is a delay in boost and there is not any boost in 1st gear and when I shift into second gear there is boost on the gauge and it comes up like what I think would be normal.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
well, 17 Atdc is very very wrong. it should be 15 btdc.
you might want to pull out a few degrees just for saftey [12-13 btdc]
not having boost in first gear is normal. theres not enough of a load on the engine to spin the turbo.
the same reason you dont get boost when you rev the car in neutral. theres no load on the engine.
turbo98_240sx
ok so yeah i looked back at the book and it was 17 btdc so i should take it back to 12-13 and should I set it up with or with out the tps on the distributor?
huguetpj
Car: 93 KAT Coupe
If you are using the greddy turbo kit with the emanage I'm pretty sure your timing should remain stock. Disconect the TPS and set the timing to 18-20 degrees.
To check for leaks the best way is to use a tire pump to pressurize the pipes with the engine off. Then ran your hand and ears through the pipes to check for leaks.
IvoryJ30t
i thought it was 15 btdc stock.
huguetpj
Car: 93 KAT Coupe
My 93s FSM says 20BTDC. I'm sure it's the same in all KA24DE
IvoryJ30t
im getting it confused with another motor.better to be a little short than tell him to run a base timing of 30 degrees.
TrunkMonkey
Car: 2000 Lincoln Navigator
IvoryJ30t wrote:i thought it was 15 btdc stock.
that's the stock timing for the ka24e.
-demetrius
turbo98_240sx
now my idle speed is high like 1,200 RPM what the deal
Structure240sx
did u unplug the throttle postion sensor (tps) when you set the timing? did u plug it back in when your were done?
huguetpj
Car: 93 KAT Coupe
turbo98_240sx wrote:now my idle speed is high like 1,200 RPM what the deal
With the TPS disconnected turn the idle screw until you get around 650rpms
turbo98_240sx
yeah its fixed and i ran pressureised air through the pipes it ran fairly good but I think there is still lots of room for improvement
huguetpj
Car: 93 KAT Coupe
turbo98_240sx wrote: and i ran pressureised air through the pipes it ran fairly good
Please explain... what exactly did you do? :confused:
turbo98_240sx
I took a hose attached to my air compressor and put pressurized air in the compression pipe and checked for leaks. There were no leaks so I took the car and went for a little ride.
huguetpj
Car: 93 KAT Coupe
turbo98_240sx wrote:I took a hose attached to my air compressor and put pressurized air in the compression pipe and checked for leaks. There were no leaks so I took the car and went for a little ride.
uufff... for a minute there I though you ran the car while putting pressurized air through the intake :D
turbo98_240sx
yeah i may sound dumb but i'm not that dumb yet
huguetpj
Car: 93 KAT Coupe
:D :D
IvoryJ30t
demcj wrote:that's the stock timing for the ka24e.
-demetrius
thanks!! i knew i wasnt hallucinating.
turbo98_240sx
IvoryJ30t wrote:thanks!! i knew i wasnt hallucinating.
I was though:ylsuper
