krazy skwerel »
https://forums.nicoclub.com/krazy-skwerel-u5797.html
Mon Feb 03, 2014 11:08 am
I have had my CA for a long time now, but it just devolped a problem where it stumbles below 4k rpm and will not make boost until 5k+ rpm. When it does finally get to the 8 psi it holds steady and doesn't drop. I have tigtened all of my intercooler couplers, checked my exhaust manifold bolts, the turbo nuts are still secured with the plates, and I changed my fuel filter and ran seafoam through the gas.
If I held the car close to redline for about 15-30 seconds while driving the lower rpm stumble would go away, but I still had little to no boost unless above 5k rpm.
The car wouldn't idle either, but I fixed a massive exhaust leak between my turbo elbow/DP and it idles now. The idle isn't awesome fluctuates between 600-1100 rpm constantly, but it doesnt try and die now. I have been searching for about 2 weeks and havent found anyone with this exact problem or if I found a similar one they never said what they did to resolve it. Please any help would be appreciated.
Mods:
Walbro 255
Megan FPR
Front mount
HKS SSQV
Isis T25/28 replacement turbo set to 8 psi
