CoolBlue »
https://forums.nicoclub.com/coolblue-u5544.html
Wed Nov 19, 2003 5:29 pm
The reason there's no boost is because you don't need any in first usually. Now, if you had like a 2.73 rear end, you would definetely see boost in first. If you put my Stock N/A KA up against a 400 hp KA, I could probably keep up in first. After first is a different story. It's somewhat similiar as cruising on the freeway, you see 0 boost, in fact, your mostly in vacumn. Because there's no load, no reason for boost.
