No, because I cant get the car in programming mode, I cant do anything else with the keyless.WDRacing wrote:Does the keyless entry function at all?
Thanks a ton! Where is the smart entrance control unit located? Noob over here.rgk wrote:Check the fuses and wiring to the smart entrance control unit. See the FSM for detailed info. If fuses and wiring are ok, you will have to replace the unit. They go for about $40 on eBay. Make sure to get the exact same one as your original.
Why Nico is awesome.rgk wrote:Download the 1997 Nissan QX4 factory service manual, electrical system.
On page 227 you will find info relating to the smart entrance control unit. It doesn't look like yours has a dedicated fuse.
Check the buzzer fuse (page 98) and remote fuse (page 186).
The buzzer section has a diagram showing the location of the SECU.
You can also search for '97 qx4 smart entrance control unit' to see what the part looks like, and what to look for.
Good luck.
Wow! Thanks for the detailed replay. I checked out those pages and couldn't really make heads or tails of them. So, basically I'm wondering which fuses I need to check in order to get my keyless entry and beeping going. Thanks for any more help!rgk wrote:Download the 1997 Nissan QX4 factory service manual, electrical system.
Good luck.
My door jam switches are fine. The light always stays off when the doors are closed.rgk wrote:Yep, I had this problem and it turned out to be a faulty door jamb switch. Try swapping it out with the one from the passenger door. Is your dome light also not working? That's another symptom of a bad jamb switch.
Great.... how does one go about fixing this?rgk wrote:It sounds like an issue with your ignition key switch, then. That might be why you can't enter the fob programming mode.
