no audio problem please help
Post all your Nissan electronics, car audio and stereo questions here!
guitar3228
Car: 1996 nissan 240sx se
my 96 SE has no sound coming from any of the speakers. The cd deck is wired correct and powers up and works except none of the 6 speakers make a sound, i checked the fuses, speakers, wiring, anyone have any idea what the problem might be??
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
rewire the whole car? thats what i did. sometimes its just easier.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
If you have a stock amp and dont have it wired you will have no sound.
You have to wire the blue wire from the radio to whatever the stock amp wire color is.
95s-14
Car: 95' 240sx/se
or if it's an aftermarket headunit with a built in amp like mine is you have to bypass the stocke amp cuz te head unit will fry it tryin to push power through it best buy fryed mine it worked for like a day then went out and they said it wasn't there fault thats wha i get for being lazy
Ghostdrifter88
Car: 2017 Taco
was it working then it just stopped working all of a sudden?
livinglegend2100
just re-wire you audio system. its not hard. and its perfect for an afternoon/night when you dont have anything to do.
guitar3228
no it hasnt worked at all yet since the radio was installed
Levissan
Car: Sold them all to buy a new one
Okay can you answer these questions right quick?
Is it factory or aftermarket HU?Who installed it?Do you have a Bose or other factory premium sound system?
IF aftermarket:What brand is it?How was the HU harness wired to the car harness?Has anything been done to the factory speakers?
Also, what is the make model and year of your car?
With the answers I can prolly help you out. shouldnt take but a short schematic response to you.
Good Luck brother,
Jesse
guitar3228
check it out its an aftermarket HU... Pioneer,stock 6 speaker audio system with stock amps in trunk.all speakers are original and check out oki dont see anything that says Bose.......the HU was wired with compression fittings utilizing a wiring harness from best buy, the constant, switched and ground are wired and the radio has lights,power and is acting normally,all 8 speaker wires are connected properlythe car is a 1996 fully loaded(power everything,abs,vicous LSD, ABS,ect) 240SX SEi never wired any switch or anything going to the amp, i dont know what color that would be....
thats all i got
