No acceleration when warm
Joey0278
Car: 2003 Nissan Pathfinder
2003 pathfinder, after starting it will accelerate but after it runs a few minutes it dies when you press the gas pedal ? No codes, new fuel pump, new fuel press. regulator, new fuel filer. Gonna try a throttle body ? Thinking it might be the gas pedal sensor ?
macgiver
Catch some ' streaming-data ' , see what they tell you ?? Parallel the right ones might getcha goi' n :yesnod
Can you do that on that year ? Duh :rolleyes:
Joey0278
Not much to look at in the way of what i need to see ? Everything looks good. Not much data on throttle body or accelerator pedal pos sensor. Gonna change tb and see what happens ?
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Check a few basic service procedures first, before swapping parts as a best guess hope of fixing it. That might work and it might not. No YouTube videos on this. Read page EC-81 of the factory service manual. https://www.nicoclub.com/service-manual ... 3%2Fec.pdf Accelerator Pedal Released Position Learning, Throttle Valve Closed Position Learning, and Idle Air Volume Learning procedures should all be performed to be certain your issue isn't just a basic adjustment problem.
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
What are fuel trims saying?
