240life »
https://forums.nicoclub.com/240life-u76914.html
Thu Nov 13, 2008 4:40 pm
I just put the first 50 miles on my fresh rebuild. The car idles perfectly, has 65psi oil pressure while driving and operates at 180 degrees. I compression tested all 4 cylinders before start up and got 150 on all of them. When the car is under no load I can rev freely with no issues...., but when I drive the car all it wants to do is bog when the turbo starts spooling. I can hit 7psi but it wil go nowhere. The car runs perfect untill the turbo starts working. I am confused to why this would be happening. Everything in the car has less then 500 miles on it before I rebuilt the bottom end. I am running cp 8:5:1 pistons, new crank, main and rod bearings by KING, eagle rods, arp hardware, tomei headgasket, nismo fpr, walbro 255lph pump, using a summit gauge to regulate fuel pressure, Greedy rs bov (atmospheric) and greegy fmic and intake. My maf is from a sohc and the wiring harness is new. Every thing was done by me both times the engine was installed and worked perfectly the first time. If anyone has any ideas as to why this could happen other then fmic clamps please chime in I am open to suggestions
