If the only symptom is that it struggles to get up to higher speeds, my guess is that the fuel filter is clogged. It's a relatively easy and inexpensive fix,
instructions are here.
If there's a rough idle or stalling, then there's a much better chance it's the MAF. You can try to clean it with MAF sensor cleaner, as it's pretty easy to access.
