NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon May 10, 2004 8:10 am
fix your vaccum leak, probably your PCV valve behind the alt or the hose to the valve. thats is why it wont idel or accel properly. Air flow meter is not seeing all the air entering the engine.
Timing light. Red lead to positive battery cable, black lead to neg battery cable, inductive pick up[clamp with a square hole in it] goes around plug wire 1, start car allow to idle, point gun at timing makes on crank pulley squeeze trigger, make flashing light illuminate the marks on the pulley and see which one of those marks the pointer on the timing cover is point at when the light flashes. that is you current timing setting do this with the car warmed up. get the sucking noise[ vaccum leak ] fixed first though or the timing check will be nearly impossible.
