coolyun_98 wrote:93/94 Canadian J30 with Traction control? WOW! I happen to own a 93 and how do I check if my J has traction control? Do I just hit on the gas really hard and see if the rear wheel spins?
Its was an option. If you have it, your instrument cluster will have a light ABS/T. You cannot turn it off. When the traction control engages, the ABS/T light will blink.
I have the original Canadian J30/J30t brochure from those years. I wish I had a scanner large enough to scan it. The brochure is bigger size wise than a copy of Rolling Stone magazine. It details how the ABS and traction control work.
