NJ FS: Lots of VH Stuff, Empty my Garage, S14 Partout
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
SuperHatch
Car: 96 TLC
This list updated on 5-3-09
VH->TH400 adaptor kit. $2250 This includes...
() JW Performance TH400 Transmission, built for 1000HP. Fully Rollerized, deep pan, reverse valvebody, transbrake, all the goodies.() BDE Performance VH->TH400 Adaptor() JW Performance 4500RPM Stall 8" Race Torque Converter() BDE Custom Cro-Mo Flexplate (Mild grinding of oil pan/rear main flange required)() ARP Hardware() Hurst Pro-Matic Shifter
Basically everything you need to put a TH400 behind your VH. This would most likely work in a Q45 as well. The only thing not included is a driveshaft, unless you have an S14 with a GTR rear, mine is useless anyway. That is basically $5000 worth of parts there. I will pallet and ship if desired. This would be great for you turbo Q guys...
95 S14 shell, this is a 100% RUST FREE very clean SHELL. This car is gutted, no sound deadening, etc. If you've been looking to make a nice S14 race car, this is a PERFECT chassis to start with. 5-lug, auto (not that it matters) and stock brakes. NO DRIVETRAIN included, Energy suspension bushings in the rear, all suspension stock otherwise. $1000.
Z32 TT Wheels with 26x11.5" MT ET Streets, tires have about 40 passes on them, plenty of life left. These tires allowed me to pull 1.5x 60' times EASILY on my S14, and the fit with no fender modification at all. $300 for all 4 wheels and tires.
2 bare VH blocks, one is already bored and honed, just needs a set of pistons and a reassembly, the other is as it was when it was torn down, just cleaned. $100 for the machines block, $50 for the unmachined block..
2 VH45 cranks in good shape, $50 each.
16 stock VH rods, $5 each
14 Stock VH45 Pistons, $5 each
Set of Early Heads, Complete $100/pair
Set of Early Heads, Bare, just heads and cam caps, $50/pair
92 Exhaust Cams, $20
92 Timing Covers, $20/set of 3
94 Timing Covers, $30/set of 3
2 VTC Solenoids, $10 each
4 Timing Chains, $5 each
2 Oil Pump Chains w/ guides, $5 each set
2 Oil Filter Housings, $10 each
Oil Pickup Tube, undamaged, $15
2 VTC Intake Cam Gears, $25 each
4 Exhaust Cam Gears, $5 each
2 Oil Pumps, $25 each
2 Fuel Pressure Regulators, $15 each
2 Fuel Dampers, $15 each
2 Sets of Early Style Fuel Rails, $15/set
2 Rear Main Covers, $10 each
2 Thermostat housings/Water Necks, $20 each
2 Sets Coolant Pipes to Heads, $15/set
1 Plenum, $25
1 Regular Throttle Body comeplete w/ sensors $75
1 TC Throttle Body complete w/ sensors $100
S14 Stock Axles, $30 pair
2 Flexplates, $10 each
1 IACV, plug damaged but still useable, $10
2 Sets Chain Tensioners, $25 a set
3 EGR Valves, $10 each
2 Engine Lifting Brackets, $5 each
2 Early Injector Harnesses, $20 each
1 Set Late Lower Runners, $50
2 Early CAS, $75 each
1 Late CAS, $100
1 Water Pump $25
Complete 97 VH41DE 138k miles with uncut harness, ECU, MAF, All sensors, even the outlets for the stock manifolds so you can make an exhaust work. $150
Stephen - [email protected] me with your phone number and I will call you back.
Modified by SuperHatch at 7:20 AM 5/3/2009
gs14racer
Emailed you Stephen, dibs on the heads.
piranhamatt
I want the headers. Email has been sent.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Did I miss something, why are you getting rid of all this cool stuff?
SuperHatch
Car: 96 TLC
gs14racer wrote:Emailed you Stephen, dibs on the heads.
Gotcha, I'm at work and won't have email access until tonight.
piranhamatt wrote:I want the headers. Email has been sent.
Will get back to you tonight.
elwesso wrote:Did I miss something, why are you getting rid of all this cool stuff?
Priorities have changed, dramatically, these past few weeks. The Z is for sale too, or being parted out. Just havn't gotten to posting it yet.
carmo
Car: 92 Accord, 90 Civic, 89 240sx
E-mail sent
SuperHatch
Car: 96 TLC
Some stuff sold... lots more still needs to go.
SuperHatch
Car: 96 TLC
See Main Post
Aussie Z
im in for both sets of early (dual port) lower intake runners if you still have them, email sent
tmorgan4
Car: 2000 Nissan Pathfinder
I'm sad to see this get parted out but I'm sure we will see the parts on some other built VHs. I wish you weren't so damn far away. I'd love to pick up one of the spare blocks and some random parts but it just doesn't make sense to ship.
SuperHatch
Car: 96 TLC
tmorgan4 wrote:I'm sad to see this get parted out but I'm sure we will see the parts on some other built VHs. I wish you weren't so damn far away. I'd love to pick up one of the spare blocks and some random parts but it just doesn't make sense to ship.
Well, I already know you'll see the heads/cams soon enough. I wouldn't sweat it, I'll still be around, just need to take some time off and start fresh when I come back.
I will pack up a pallet and send it freight if you want. The shipping might be $150-200, but if you buy enough stuff it would definitely make it worth it.
John Dixon
Car: 300ZX-TT Z32
How much do you want for the early type coil packs? Might be worth me having some as spares.
piranhamatt
You guys will be seeing the headers on an s14 soon as well!
Carl H
do you have any complete stock blocks (dirty or not) and this means full drop in.
SuperHatch
Car: 96 TLC
Carl H wrote:do you have any complete stock blocks (dirty or not) and this means full drop in.
Unfortunately no, I do have a complete 98 VH41 Engine, manifolds/sensors and all that I'd let go for $200.
WizardBlack
Car: 1977 Datsun 280Z w/ RB25DET
The Clevite bearings are "standard size", yes? No variation or undersized, etc.?
All VH45DE rods are the same?
SuperHatch
Car: 96 TLC
WizardBlack wrote:The Clevite bearings are "standard size", yes? No variation or undersized, etc.?
Yes and Yes....
WizardBlack
I would like a set of the Clevites. I will send you an email. I also need some other bits, but have to break one of my VH's down to see if I have everything I need in it or not.
Getting out of cars for the time being?
SuperHatch
Car: 96 TLC
See First Post, UPDATED TODAY
Donyal
Car: 2009 Toyota Tundra SR5
I sent you an email to the address on your profile, I want to get a few of the main parts in your setup.
sooshd
Car: G35
i know its a LONG shot... but any chance you still got the s14 shell?
Return to “VH45DE / VK45DE / VK56DE Forum”
