Is there a way to tell which lot my 08 is in?DJBeasy wrote:Im not sure thats true. I received an extension to 2012, not 2013. There were two "lots" of 2008 models IIRC, first lot manufactured between 04/2007 and 07/2007 and the second lot is anytime after that. I have a feeling if you are in the first lot, like me, you might not get extended past 2012.
Whatever your current inspection sticker says, add a year to it. It has nothing to do with your VIN. For example, mine was due for 5/12, and now I'm due for 5/13. And heres the article from the DMV if you're interested:funkee wrote:Is there a way to tell which lot my 08 is in?DJBeasy wrote:Im not sure thats true. I received an extension to 2012, not 2013. There were two "lots" of 2008 models IIRC, first lot manufactured between 04/2007 and 07/2007 and the second lot is anytime after that. I have a feeling if you are in the first lot, like me, you might not get extended past 2012.
