grk nickafis »
https://forums.nicoclub.com/grk-nickafis-u138649.html
Sun Feb 02, 2014 3:19 pm
My girlfriend has a 2005 Altima SE-R. After taking it to many different places to get work done, I've convinced her to do the work ourselves (by ourselves i mean Myself.)
It was previously taken to a really chitty mechanic that put ATF in the 6sp Manual trans. After drainins and refilling a few times at a different shop, it still was not the right fluid.
She is experiencing a tough shifting feel and i blame the fluid. The clutch master, slave, flywheel and pressure plate/disc combo are all new. Also, these shops have since stripped the fill/drain plugs.
I bought the proper oil from the dealer (75w90 GL5 is what I was told is correct)
It's hard to find literature on this car so I come to you guys wondering, How many quarts does it take (i understand to fill to the bolt hole but approx how much is that so i buy enough)?
What's the best way to get the stripped plugs out? There are two different part numbers for plugs on courtesy nissan, i bought both just in case but what is the difference?
Also where can i download the FSM?
I don't come on that often so my responses will be slow but any/all input is appreciated. Thanks.
-Niko
