Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Thu Mar 27, 2003 4:05 am
Straight from Aries himself and with my spin...
Nitrous for the turbo cars is used in the lower rpms. It is used to create more thermal energy in the exhaust. This in turn spools the exhaust vanes on the turbo earlier. Hence a "spool up" kit.
Spraying under boost brings all sorts of tuning problems and issues to hand. It is VERY easy to go wrong with nitrous mixed with turbos. Often when you spray you get large spikes causing a sudden lean condition, then detonation, then pre-ignition of th next mixture. Voila, nitrous backfire through the intake tract and you've blown the head and god know's what else. BTW, your motor is still spinnin up in the RPM when this happens.
Let the carnage begin.
