SHiFT »
https://forums.nicoclub.com/shift-u6875.html
Fri May 23, 2003 10:54 am
I read the Nitrous Faq but its not too specific to the 240. My brother is knowledgable about nitrous and says I'd need to replace the clutch if I started spraying. Is this true if I installed a 75 shot? I'm on a stock clutch right now with 65K miles and the owner before was a sweet girl that I know didn't drive hard at all, it still feels pretty solid. What else would I need to upgrade to run a 75 shot? I say 75 because I see people on here are going up to like 125 with no problems, but I don't want to stress the engine that much because the newer KAs were built weaker than the older ones. Also, some of the other threads mentioned that the NX kit is the best. This true? Thanks all
