Redline240 »
https://forums.nicoclub.com/redline240-u3445.html
Wed Feb 18, 2004 10:09 am
Well i was thinking i would use a MSD 6AL for the timing retard so that i can still maintain good NA hp...i just used the 75 as a reference for the dry shot, i'm planning 200+ shot of direct port with maybe a 75 wet off the launch...the pistons will have to go out for some forged ones and probaly the rod bolts too, but most of the rest of the internals should hold...some S13 cams, p&p, HS header, custom intake, etc...
But back to the fuel, i have a walbro 255 inline and i was thinking i'd add a 255 intank as well....also i'd like to upgrade the lines to -6 and run it to a distribution block with a return. Then from there one line to the fuel rail, one to the direct port selinoid(sp?) and one to the wet....
Also, is it possible to run both wet and direct port off the same bottle? Couldn't i just use a T or Y to seperate the main line? Both wouldn't never be use at the same time...
My concept obviously needs refinement, so please improve on it!
Redline
