encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Sun Mar 09, 2003 9:03 am
I am contemplating using nitrous oxide in my 92 240SX, it is a daily driver so I only want to use a dry 50 shot. I have a couple questions however:
I don't want this to be complicated, this is my daily driver, all it has is an intake, muffler (from previous owner) and I may soon add the ASM pulley. A few other things like removed mechanical fan and suspension work I also have. My plan is for a 10lb bottle and only to be used once in a while, maybe 5 times a month or so. I chose dry because it is more simple than a wet, now my questions.
If I buy a used wet kit, can this be used dry, as in just not using the fuel solenoid?
What is a pass exactly? I see people saying a 10lb bottle will last 10-12 passes, is a pass a standing 1/4 mile? I don't drag race so this is more for a boost on the highway. How many 45-113mph runs will this support? I suppose only all of third and fourth gear only and maybe part of second occasionally. Is it possible to arm it and not run it in 1st with a normal setup even though it is armed in first?
And what's the least number of things I can get by with for this 50-55 shot. A bottle, jets etc. Do I need a bottle heater? Gauges? Purge valve? etc. I would like to get by with the minimum to make my setup reliable. I don't mind retarding base timing a couple degrees or anything, all i want is a window switch to activate at full throttle when armed. Thanks for the help.
